Well I heard that bad things happens in 3s. The starter went bad, oil is leaking from the rear main seal and coolant is leaking from the lower radiador hose.
Replaced the starter and forgot which bolt goes where since they're different and stripped the lower threads.:bawl:
Then replaced the lower radiator hose and still leaked coolant, so I put in a new water pump and thermostat, now I don't have heat.
I don't know how to approach the rear main seal, the service manual says to lower the front suspension and the chilton recommends to lift the engine either one don't mention removing the transmission cooling lines to access some of the bolts on the oil pan.
Also I changed the oil and filter and now oil is leaking thru the filter, looks like is comming from the adapter, maybe the seal broke.:flamemad:
Mike :hang:
Mike :hang:
