Backspacing on fullwidth axles...
this is with 17x9 rims with 5 inches of backspacing
ill be at 66-67" wms with 3.5" BS on an 8" rim
ill let you know what happens once it gets together.. (rear is done, front soon hopefully)
welli use flat top knuckles with high steer arms on them.as well as a factory tierod bar and ends for a 79 F150/Bronco.with 17s you clear the stock tierod mounts on the knuckles.with 16.5 you will clear the stock arms but 16.5 rims suck for holding a bead unless you run beadlocks
