wavingpine11
- Central PA
I don't have any experience with OX lockers, but it seems strange that running the cable in that arrangement is the best option. Don't they make a cover that engages from the other side? Is there a driver or passenger side diff option?
Unfortunately, the cable has to approach from that side or it wouldn't be positioned to do its job. That's the "non-ring gear side" of the differential, and the cable pushes on a piece under the diff cover that fits into a grooved collar on the differential that in turn pushes a locking piece into engagement with the spider gears to prevent them from turning, thus completing the locking action. The ring gear would be in the way if the cable came from the other side.
OX also sells air- and electric-activated systems that do the same thing and wouldn't be as hard to route as the cable, but my cable lasted 5 years before it got crushed by something that prevented its movement and necessitated its replacement. I wheel over discarded treetops every now and then since the loggers leave them in the woods, and some of the "woods" seems to include the trails they (and I) use. The way I see it, a wire or air line probably will suffer damage more easily than the cable, which is actually quite robust, under such conditions.
Some people say that they have trouble setting the cable up. I've done it twice with two different cables, and I've had no problems. I just followed the instructions. I did end up stuck in a big freakin' puddle when the OX cable went bad, though. Kind of ruined my carpet, but life goes on. I bought a "drive-away lock" when I ordered the new cable. You can screw that in after removing a faulty cable and manually lock the differential that way in a desperate situation. Hopefully I'll never need it.
