Axles for Rocks
CRASH said:
OK, having had good response to the gearing thread that resulted from almost slitting my wrists at the thought of reading another gearing question, I bring you "Axles for Rocks". A definitive overview of the axle/tire combinations that I have seen work, and fail, in ten years of wheeling granite, slickrocks, cobble and volcanic nastiness. The last 4 or 5 of these years I have been building and fixing axle junk as well.
Disclaimer: I know nothing about wheeling in mud, except that I hate it. I have no idea what works and what doesn't, but if you follow the rules below, you'll have no trouble in the goo.
Disclaimer #2: The below is for XJ's. They run about 5,000-5,300 loaded for a trail run and a weekend of camping. They have 4.0 to 4.7 liter motors. If you have other junk in your junk, write your own damned thread.
Rear axles: The weak link in most rear axle setups is the shaft itself. C-clips, Set bearings or full-float makes no difference in torsional strength, it's all about axle shaft diameter. Lockers add a huge load to shafts, so you'll see two numbers for each axle. That said:
MTS (maximum tire size):
Dana 35: 31's with a locker, 31's without a locker. (This axle doesn't care if it's loaded or empty. It just plain sucks.) Weak housing, thin tubes, and a small 7.5" gear don't add up to much. I've seen them successfully trussed with a 30 spline kit stand up to 33', however.
29 spline Chryco 8.25: 33's with a locker, 35's without a locker. I just can't trust a 29 spline shaft to 35's with a locker. MAYBE with upgraded shafts. Good stiff housing, though, which contributes greatly to carrier and ring gear strength. upgrade your 27 spline to 29, and you'll gain these benifits.
Dana 44: 35's with a locker, 36's without a locker. You can super-fy this axle with 33 and 35 spline shafts now, but the pinion becomes the weak link. They are a fairly good axle for most duty, but housing rigidity can become an issue with larger tires and high speed romps. Their tubes are not much larger than a 35. You could go 37's with 35 spline shafts if you kept your foot out of the throttle.
Ford 8.8: 35's with a locker, 36's without a locker. Very similar in strength to a 44. Carriers are a weak link when used in extreme environments. New carriers are being introduced to address the weak 2 pinion carrier design. Shafts are beefy at 31 spline, but no diameter upgrades are available. Pinion shaft is very beefy, same as a 9". Weld the tubes all the way around to the pumpkin, or they WILL spin.
Toyota 8": 35's with a locker, 36's without a locker. I'm always very impressed by Toyota quality, they are worlds ahead in quality control and tolerances. The Toy 8" uses the same shafts as a Dana 44, 30 spline, but with a bunch more ground clearance.. The case is more rigid, and has a bit more hypoid offset too, which helps in R&P strength. The Toy guys flog this axle pretty hard with 37's, but I have seen enough break with that size tire under 22RE 4 cylinder power to make me keep the limits at D-44 levels for a much torquier 4.0.
Ford 9": Special mention for this axle. It is very stout. Shafts are available in 28, 31,33,35,40 and maybe 46 spline. All are not created equal, though. A crappy OEM housing and center section will flex like a wet noodle. Do yourself a favor and get a good Strange nodular iron case and a nice stiff Currie Extra HD or Diamond housing as a base. Built this way, and with 35 spline shafts, it has no trouble holding 39" tires. The pinion is way low on these, which is why most of us that run the deep rocks shun this axle. The pinion always seems to be spinning on rocks. Edit: The new series of high pinion cases made by Currie and TrueHi9 deserve special mention, as Brett points out. The Currie unit is truly a Ford reverse spiral 8.8 from the front of an F-150/Expedition. They lack the third pinion support and hypoid offset of a 9" ring and pinion, and thus have limitations when used in the rear (remember, that's running on the coast side of the gear set). 35's is the limit on these, even though you can get it in 35 spline, it's a waste, because the ring and pinion are weaker than a 31 spline shaft. The TrueHi9 folks have addressed this by having Richmond cut a true 9" reverse spiral gearset for them. They have also included extra ring gear deflection support and a nodular housing for extra beef. 35 spline axles plus this case and you're good to go to 39's. This will be my next axle when I finally break my 8.8 (again).
Dana 60: Yummy. Can accept 30, 35, 40, and 46 spline shafts. Very stout cases and large tubes make this a desirable axle. The pinion is very large, the ring gear is 9.75", and the carrier bearings are huge. This is the axle you want if you want to run 40" tires, larger if you go with a 40 spline shaft. A high pinion unit will accept less than this due to running on the coast side of the ring gear, but still, it would have no trouble with 38's. Easily trimmed and weldable case make this axle fun for shaving and adding link mounts.
Dana 70/Ford 10.25/14 bolt: This is the true one ton series of axles put out by the OEM's. They are fine and dandy, but the parts and gear ratios can be limited, bigger shafts are more difficult to run than a 60, and they tend to have more ring gear strength than is really necessary for a Jeep. The ring gear size comes into play when towing, not really in Jeeping. This makes them more difficult to trim, as the gear fills most of the case. These axles all have 1.5" diameter shafts, (35 and 31 spline due to difference in spline size), and as such, can be run with the same tires as a 60.
Rockwells: A fine axle. Difficult to fit, impossible to re-gear, and quite portly. They can never-the-less handle 44's with ease on a non-sterring axle in a rear application.
I haven't worked on the various portals out there, so I won't speak to them.
Front axles to come tomorrow.
CRASH
Wheres the front axle info?
dave92cherokee said:
Seems to be pretty close to the layout on jp magazine http://www.jpmagazine.com/techarticles/154_0708_weakest_to_strongest_axles/index.html
Page 1 is front axles and page 2 is rear axles.
John Cappa is an idiot.
17. Ford 8.8 (Ranger and Explorer)
Some versions have weaker 28-spline shafts. The '91-'01 Explorer 31-spline version is preferred ('95-and-later have disc brakes). There's a lot of aftermarket support for the 8.8, but the C-clip shafts are a notable weakness. Commonly swapped into Wranglers in place of the Dana 35, although the marginal gain in strength hardly seems worth the effort.
:laugh2:
Yah never said they were smart and knew what they were talking about just reminded me of the layout they had. They probably rate them off of numbers instead of real world ability, especially the Dana 135 rear, how many have ever seen one of them let alone under a offroad rig.
Yeah, I read that link and thought they must have been smoking crack when they wrote it.
