- Foresthill, CA
NXJ said:Think again. :looser:
Actually, the 14sf is stronger than most OEM 60's. Better hypoid offset and 33 spline vs. 30 spline shafts.
Oiling.snow580 said:What would be the problem with this?
feelinsomewheelin said:Concerning the ford 8.8, crash said "Weld the tubes all the way around to the pumpkin, or they WILL spin." I am plannin on putting a 8.8 in my xj soon, could someone explain what he ment by this, i dont know too much about axles.
CRASH said:OK, having had good response to the gearing thread that resulted from almost slitting my wrists at the thought of reading another gearing question, I bring you "Axles for Rocks". A definitive overview of the axle/tire combinations that I have seen work, and fail, in ten years of wheeling granite, slickrocks, cobble and volcanic nastiness. The last 4 or 5 of these years I have been building and fixing axle junk as well.
29 spline Chryco 8.25: 33's with a locker, 35's without a locker. I just can't trust a 29 spline shaft to 35's with a locker. MAYBE with upgraded shafts. Good stiff housing, though, which contributes greatly to carrier and ring gear strength. upgrade your 27 spline to 29, and you'll gain these benifits.
I haven't worked on the various portals out there, so I won't speak to them.
Front axles to come tomorrow.
CRASH
Dreamin4x4 said:Thnx for the Info! Althougn in the Begining are u talking about the 27 spline Axel then the 29 cause U kinda Jump at one point Cause I was gonna Ask I have a Chryco 8.25 but its a 27,
JSut wondering if i could get that cleared up
Cheers
Dreamin4x4 said:Srylemme say that again Crash you Start with the 29 spline and then! jump saying that you should upgrade the 27 to the 29 which I found counfusing cause u were talking about the 29 to start with
cherokee chuck said:Has anyone ever used the 8 3/4" Mopar axle? I have had several big block mopars and a 1/2 ton truck with this rear end in it.Most 440 equipped muscle cars had it, not the D-60. It's available in 4.56 & higher ratios. Is there a reason not to narrow one for use in my XJ? I can get one from a late 60s wagon that has 11" or 12" brakes & was wondering if it would be worth using. I've narrowed both 8" & 9" Fords in the past so I can do the housing myself, but I'd like some outside input on this. Great thread!!:dunno:
Phil said:29spl 8.25 is decent.
If you have the 27spl 8.25, you should upgrade it to 29spl.
So what is the question?
