Axle yoke question
marcusguy
Jing Zhou, China
My friend busted his u-joint and yoke on his rear dana 44 tonight. I have a spare d30 yoke that I know uses the same size u-joint, and I remember from setting my gears up that the pinion nut is the same size. Is there any possibility that they are the same? Is the spline count and diameter the same? Thanks.
marcus
A quick check shows both are the same .26 spline same part #s.
You are good to go.
Wayne
