Well I am getting close to finally needing to order the bolts.
After spending 4 months, including battling the Harvey flood, a flooded house and shop, we have now finally gotten the rear leaf spring 100% off the spare 87, and recently the rear bolt, it was a true die hard, hat to cut n gut it out in 4 pieces, then the outer steel bushing part on the front bolt, then the rubber, and now after 3 weeks of using a torch, a BFH and chisel, and a massive electric industrial nut buster impact wrench, a dremel tool with a diamond cutting blade, and finally a new air hammer chisel I bought this week, we finally got to the inner steel sleeve on the front bolt, and got it loose enough to spin free of the bolt, LOL.
Now just need that massive industrial electric Impact back on loan from our buddy (my new air powered 600 ft-lbs Impact tool just gets laughed at still).
But repeated heat (torch) on the nut/bolt end, and water soaks to chill and shock it, and then pen lube, and then the impact should finally get it loose now.
May need to hit the sleeve one more time with the Dremel tool/diamond mini wheel to cut the sleeve open closer the rear nut to better access for heating and pen-lubing of the bolt end near the nut/frame area, as we were not able to fully open up and remove the sleeve, just able to detach/un-glue it from the die hard bolt.
Long story short, I see daylight
(or is it sun set, LOL) on this endless one afternoon repair nightmare LOL.
