Stumpalump
- Franktown Co.
I was told by a few dealers that they have a lot of warrenty claims on the Yucon axels. Just what I heard.
Stumpalump said:I was told by a few dealers that they have a lot of warrenty claims on the Yucon axels. Just what I heard.
I said that?? :laugh3:Rod Knee said:Well, I brought this whole issue up after reading Zappe's book on building up the XJ. He says stay away from the chromoly,
EricsXJ said:1541 vs 4340
Cal touched on this a bit but here it is.
1541 is a softer alloy shaft compared to 4340 Chromoly, but still much stronger than stock. I believe most companies make their rear shafts for the XJ out of 1541 and the reason for that is because it is a semi-floating axle (so is the front BTW). This means that the axle shaft bears some of the weight of the vehicle. Because of that the axle needs to be able to flex or bend a small amount and not break. 1541 is ductile and can accomplish that. 4340 Chromoly is stronger but it is less ductile, and therefore (in theory) not the best choice for use in a semi-floating axle.
HOWEVER.... there are a few companies like Superior who are making their rear shafts out of 4340 Chromoly even though it is in a semi-float axle. In discussing it with them, I was told that it would still be okay to use 4340 for the XJ because of how light the vehicle is. I have 1541 Yukons in mine now but may switch to Superior later this year. I believe they are right, but we'll see.
EricsXJ said:I said that?? :laugh3:
XJME said:Well, I won't give any advice as I am kind of a newbee myself, but if you want a 8.25 with a 29 spline and a 30 with alloy usa axles (both have ARBs) I am upgrading and I will sell you mine. They are in a cherry 2000 xj with 42000 original miles. You can drive it with the axles in it. The gears are 3.55s. Too tall for me, I'll be pulling a trailer over mountain roads and they won't work. Have receipts for everything. $2000 takes it all. I need to figure out how to turn on my pm so just reply if interested.
Rod Knee said:Well thanks, but I'm not ready to do anything yet, except furthering my education and getting off the steeper part of the learning curve.:lecture:
Rod Knee said:Well, thats what I got out of page 78 where you state: "4340 is reserved for full floating axles" and "all stock XJ front and rear axles have semi-floating shafts". You do make an exeption in the case of the hub conversion (which would seem to be to pricey for me for its worth). Anyway, did I make an incorrect inferrence from that statement? I am enjoying your book.
By the way, I used to live in Nevada too...Elko, Eureka and Austin. Wheeled extensively as a geologist in the mining industry. I remember times when the front and rear wheels would get in different sets of ruts in the mud...you'd have to look out the side window to see where you were going. Those were the days.
mjma said:Good stuff man, I'm a geologist too, actually a hydrogeologist. Geologists gotta wheel!
