Ecomike
NAXJA# 2091
- MilkyWay Galaxy
Planning to drain some old fluid from my 87, the one that slips at cold winter start ups. Will top off with fresh fluid. Planning on using the dip stick and a pump to suck old fluid out instead of messing with pan and gasket. Will try that for a week then try adding some Trans-X next if the slipping remains with no other changes.
I found real Dexron I- II-III at Autozone made by Coastal! Seems they still make it!!!!!!
