Hi guys, sorry for the wait, but i've been bussy with my Day Job
allright so for an update.....
1. The board is ready to ship, however to keep costs down shipping will be by small parcel normal air mail.
2. In order not to break the forum rules, the price and ordering information will only be done through PM and e-mail....so if anybody is interested sent me a PM and we will take it from there.
3. Still have to finnish the instruction sheet and installation write up
4. Here is some more pics of my install
The TCU as found under the dash, on the pasenger side..
The wires seperated, cut and the diodes soldered in, ready for the tiptronic wires...however read the bottom of this post for and update on the use of these diodes.
Fitted a 25 Pin D-sub connector to the enclosure, works great! The ribon cable is just to power the 7 Segment display, and note that the other wires used are all MIL spec (very expensive)
Temporary location of the Joy stick shifter, for testing....the small togle switch to the right of the floor shifter is to engage the Tiptronic/Auto mode....Probably will use buttons on the steering for a final install, not sure yet!:dunno:
A small and inexpensive Tach to keep an eye on engine performance in manual mode
A view of the gear indication from the driver's perspective...it's not as bright as on the photo(camera light trick) however it is clear in both day and night use!
After using it a while i noticed a lot of heat generated by the TIP 120's so i fitted a bigger heatsink and then for the hell of it i also fitted a 12V CPU cooler fan that I had laying around...total over kill but it ads to the WOW factor...and really helps to cool it down!:laugh:
Ok so back to the diodes....
as part of a design i'm thinking of for the 97+ guys that trips the CEL when doing this mod (or any of the others available) i droped the use of the diodes and now switch the solonoids from Auto to Triptronic mode by using a small relay board..sorry didn't take any pics of it but will if anyone is interested! this allows me to leave the TCU power on.
added to that i'm gonna build a circuit to "alter" the signal that the NSS sends to the TCU, then use the relay board to cut power to the soloniods, and if i'm right this would allow for any external signal to be send to the tranny without tripping the CEL , just have to find a willing test subject...
will update when i have the circuit done...
Later
