Aussiexj96
- Australia
Hey all,
Im new to the forum and thaught i would put up a brief wright up on my cherokee. Im from Australia and most of my mods have been done by myself and my neighbour with the exception of the transmission and engine work.
Im running a 96 XJ Sport, i baught it stock and since then;
Suspension:
4.5 RE superflex kit with rear leaf
ACOS front coil spacers, Rear extended shackles
SS braided brake lines
Procomp 24" bigbore shockies
RE GEN II quick disconects
Tires & Rims:
Cooper 32 x 11.5 stt's
King steel sunrasia (gloss black)
Engine:
4.8L stroker kit + custom crank and cam
Custom alloy radiator (40%) bigger than stock
3 x electronic thermos 2 x 12", and 1 x 10"
K&N apollo intake with snorkle + bored out TB and spacer
Upgraded injectors - Bosch EV6 36p/ph, 4 pin spray pattern
Mopar headder and 2 & 1/4 exhaust dumped b4 the rear diff (custom made)
Transmission:
AW4 rebuilt with;
High volume oil pump
Kevlar pick up's
HD clutch packs
Stage 2 shift kit
Transfer:
Stock 242 with RE SYE and double cardon drive shaft
Diffs:
Front;
Dana 30 HP with Yukon 4.11's and RD100 ARB locker, Moly axels
Rear;
Dana 35 with Yukon 4.11's and RD101? ARB locker, Moly axels
Extras:
Lightforce XGT HID 240's
Rear steel Bar
Uniden UHF police scanner
Tail gate lights 4 x cold cathode fluros
Scan guage 2
Manny manny more small personal touches
Bushwacker cut-out flares
Reflexxion Steel cowle bonnet
All carpet removed and marine grade 2pak epoxy applied
Rear quarter panel chop
Mods on the go ATM:
Dana 44 steer from an FSJ - 6 month build
Dana 60 rear from a dodge - 6 month build
NP231 transfer - on the way from aussie jeep forum - Done by end of jan 2010
Intake manifold modifications - custom air plenum tunned runners - Done by end of jan 2010
Haltech 2000 sports ECU and custom made wiring harness - Installing next weekend
Pictures - will upload some more soon, will also take pics of "mods on the go" projects.
Cheers and hope you all enjoy
Aussiexj96
Suspension:
Tires & Rims:
Engine:
Transmission:
AW4 rebuilt with;
Kevlar pick up's
HD clutch packs
Stage 2 shift kit
Transfer:
Diffs:
Front;
Rear;
Extras:
Rear steel Bar
Scan guage 2
Mods on the go ATM:
