- San Diego
the company is Revolution gear and axle.
they don't have an exact date yet, but it will be in the next couple of months.
On that not of a fuse I prefer having one in my front end. It isn't that much weaker than the rest of the axle, and I would rather change a hub in 5
Minutes then an axle shaft in 45.
I'm not sure I understand. If you have the hub out swapping an axle shaft is seconds?
Revisiting the original posters original question:
My general rule is this: 32's and down stock shafts are fine. At 33's I want alloy shafts. Thats for california wheeling, some go fast, some rocks, some mountains, no mud.
I'd go as high as 31's on stock gears, but by 32's, I want to install some 4.56 gears, and for 35's 4.88's or 5.13's.
I have owned 6 XJ's in about 10 different configs, and built another half dozen or so with other people. My experience has drawn the lines above.
I agree with some points cal but here in New England I prefer stock shafts and stock gears in a "wheeler" lots of wheel speed has killed 2 dana 30 and one dana 35. Surprisingly my 8.25 has held up quite well. My reason for the stock gears and shafts is ease of finding spares. I went through to many axle shafts and unit bearings (that does include the chromoly axle shafts I found at the junkyard) before I "rebuilt" the dana 44 I'm running. The 3.55 gears suck and the stock shafts aren't the best but I had great luck running abs shafts. This is wheeling with a lot of mud and rocky terrain.
This makes no sense at all.
Why would stock gears make spares any easier? Are you setting up gears on the trail? And carrying spares?
Same with stock vs alloy shafts in reference to spares. You'd still source the same stock spares if you had alloys, you'd just break a lot less often. They are a bolt in replacement, but 30% stronger..
or you could run a quality alloy shaft and not worry about it, not have to break on the trail and spend time swapping.
my alloy shafts are nearing 15 years old living that almost all of their life on 35"s with a healthy diet of rocks.
How many full throttle muddy assaults?
none.
its a dana 30 and I treat it as such.
So that doesn't apply to wheeling in New England.
If you wheel your dana 30 like it is a dana 60 you should invest in a dana 60.
