goodburbon
- Westcliffe Colorado.
I've run
Front/Rear
Open/Open
Open/Trac-lock
Tru-trac/Trac-lock
Trutrac/E-locker
ARB/E-locker
Open/Detroit
Lockright/Detroit
Unfortunately the rig with the 242 has the 2 autolockers. For off-roading and maintaining streetability you can't beat the 2 selectable setup. Running a selectable rear/truetrac front allowed me to use the brakes to lock up the front, but I went through 2 ring gears, several shafts, and a few u-joints Using heavy throttle and brake to hold a lock. Since switching to selectables all around, I wheel harder and break less.
Being that the front brakes are a lot stronger than rear, I wouldn't think you'd be able to get a full lock out of a truetrac in the rear.
Here is an example of me with the truetrac front. You can see the wheelspin change as I change pressure on the brake pedal. The next time I attempted this obstacle, by the way, I lost a ring gear.:gee:
http://www.youtube.com/watch?v=EEjDQ5H0bK8
Front/Rear
Open/Open
Open/Trac-lock
Tru-trac/Trac-lock
Trutrac/E-locker
ARB/E-locker
Open/Detroit
Lockright/Detroit
