seymouj
NAXLA Member #1223
- Shingle Springs, CA
My ARB's have been installed for a couple years now and have worked flawlessly until now. After being parked for a couple months, when I turned on my rear locker (d44), air was blowing out of the axle vent, enough so that the compressor couldn't keep up. After driving it all day, I tried it again and it worked like normal.
On the Rubicon last weekend (first wheeling since then), it worked well all morning, then did the same thing again (Of course it decided to not work at an obstacle where someone broke down and traffic backed up and by the time it was finally my turn to go through, there was an audience and I had to do it minus one locker in front of everyone). Later it worked again and was intermittent the rest of the trip.
When it does engage without blowing air out, it does not leak and works well.
Last night I pulled the cover and everything looks normal, plenty of oil, nothing broken.
I have read of people having issues with the diff not venting and pressure building up and oil filling up the air lines causing the locker to not work, but I seem to have the opposite problem.
After all this typing, my question is, does this just sound like I need a new O-ring? If so, why would it work sometimes and not others?
I'll probably pull it out tonight, anything else I should check?
