jrowell
- Bakersfield
mecompco said:We actually discussed doing extactly that. The problem is that the stock mounts are right there, and are an integral part of the bumper. I'll take a picture of the back showing this. Basically the extended mount is right up against, and now welded to, the stock mount--the bolts will go through both the extended and the stock mounts. Also, for a side pull, the stock mount is directly behind outter angle iron for extra backing.
The back side of the extended mount is also welded to the back face of the bumper. So, 1/4" steel straight through, then another 1/2 of angle iron on each side. We used a 400 amp welder at my buddies work (railroad--every tool they have is super HD) for good penetration.
I ASSumed you had a reason for your design. Good to know!
