blondejoncherokee
- sacramento
i was wondering if anyone in the sacramento area could come by for like 20 mins one day who wouldnt mind test driving my xj with me and maybe doing a quick check of anything i might have missed. i still have vibes, and i dont know where to go anymore, and maybe one of you more seasoned vets could maybe have a better idea after a quick test drive and a look at the steering and maybe the driveshaft angles. im confused anymore. ive replaced so many parts and still stuck with vibes, just not as bad anymore. i would totally give a 24 pack for sure and maybe some cash if you could point me in a good direction. im trying to avoid a sye if i can, but ill gladly do that if you guys think thats my only option, but i want to get any other possibilities outta the way first.
do motor mounts have a break-in period? it started to happen significantly worse after i did the first motor mount
-i have done the lca bushings,
- driver side uca with frame end bushing on it.
-both hubs are new
- 2* shim under rear packs to account for axle wrap.
t case drop
-tires balanced
-new motor mounts and newer but used and in better shape tranny mount
-new doetshe shocks from rustys(could these shocks just be garbage? and giving me vibes) with rear bpe's
-yj slipyoke and retubed rear driveshaft
-pulled front shaft off for a while, still have vibes.
-brakes are good, new rotor on driver side with the newer hub with the 297 shaft from a 96
-jks quicker discos
-stock toe hooks with the better bumper mounting and more mounting points that go further back
- new zj tie rod
-ball joints seem good, no play in wheels from what i can tell
-ive done my alignment a few times, but i was thinking maybe to take it in to a shop, maybe im not on point with the alignment and maybe having the tires checked agian for balance???
-both hubs are new
t case drop
-tires balanced
-jks quicker discos
- new zj tie rod
