watson
- Cincy, Ohio
A buddy of mine was looking into the Dana 300 flip kit instead of doing an SYE on his 231. You can get a twin stick with 2lo for dirt cheap and the gears in the 300 are definitely stronger than chain in the 231. We were looking at an early Bronco and noticed that it uses a Dana 20 T-case with a driver's side front output. Aren't the 20 and 300 interchangeable as far as mounting (or are ford 20s different than Jeep 20s) and aren't they about the same strength? So why couldn't you just use a 20 from an EB instead of flipping a 300. Anyone consider this before? Thanks.
