anyone got any?
goodwilljeeper
Pleasanton CA
looking for a cheap pair of sliders for the rubicon that fit..just seeing if anyone has any here before i either buy some or run without em
also looking for the 231 shift plate. (green plastic lights piece that goes on the shifter telling what each 4x4 is at.)
thanks
well x-ay on the plaque. i got one from casey. and the plan is to do full rocker replacement with 2x6 steel but i was just looking for a small easy set for the con cause i can't do the replacement before i go
go to local steel supply. spend like 40$ on some 2x2 .120 wall, 5$ on some 3/4x3/4 square for the pinch seam mounts, and 15$ on some 1/2 .120 wall rectangular tubing for the 3 legs per side. and build them. call it done. be into it for 60$.
I spent about 80$ in steel from sims metal to build my set. Came out a little warped because I had like an hour to do the final welds on top of a crooked table.
10' of 2x6 3/16" tube and a sawzall, then find a welder, best way to stiffen up the unibody a whole lot and save a couple inches of ground clearance while youre at it
Sam is in a tough spot right now as far as building sliders goes. With no welder, no grinder, no garage, and no time, that's not really an option at this point lol.
