philip_g
- back in CO
I pulled mine apart and now I need the tool to adjust it
and if the answer is yes, can I borrow it?
philip_g said:I pulled mine apart and now I need the tool to adjust it
and if the answer is yes, can I borrow it?![]()
87xjco said:I have one you can borrow, I'm near 66th and federal.
Terry
Wow, I'm in and out of your neighborhood all the time. That's good to keep in mind.87xjco said:I have one you can borrow, I'm near 66th and federal.
Terry
I'm in castle rock, I can drive the GF's vehicle just need to shower and degrease.87xjco said:Man that's weird, two Colorado people took their 8.25's apart recently and don't have the tool, hope trouble doesn't come in three's!
Do you not have any way to pick up the tool?
Where are you located?
I borked itFrank Z said:So whats wrong with your axle Philip?
Frank Z said:Any chance you accidently put both thrust washers on one side gear?
I'll pop the cover again and take a quick peek this morning, if that isn't it I'll junk the axle.Frank Z said:If you left one out of place it might cause the chattering noise.
I'll have to pull the axles too anywayFrank Z said:Better pull the cross shaft, side and spider gears while you're at it.
they're in place and look A-OKFrank Z said:How about the thrust washers on the side gears?
