2xtreme
- Kayak Pt, WA
Here are some photos of mine.
On the inlet side:
1. generic air filter from a lawnmower with an inlet that matches hose used.
2. rubber hose
3. tool oiler with brass hose barb to accept both hoses.
4. rubber hose over the original inlet tube
On the outlet side:
1. brass adaptor to go to standard fittings for the rest of the air fittings (1/4 npt? I think off the top of my head).
2. 1 way valve so air pressure doesn't damage pump.
3. filter
4. 4 way valve with pressure releaf valve (150psi?) and pressure gauge and quick connector (shown in picture as hose barb).
5. Hose to tank.
These are old pictures of how I first set this up. I now have the additional tank and pressure switched set up and I would have to take new pictures to show these also. The way this set up works you have to pop the hood and turn on the switch. Now I have the pressure switch to keep the system charge or turned off inside the cab and have quick connects on each tank (front and rear bumpers) so I have air at pressure at anytime I am on the trail.
The only issues I had was with the hose barb and cheap yellow hose to the tank. When I replaced it with a quick connect and decent quality hose all issues were resolved.
Does this help?
Michael
On the inlet side:
2. rubber hose
On the outlet side:
3. filter
5. Hose to tank.
Does this help?
Michael
