I did the same swap in my 87 MJ......there's a cover plate on the trans tunnel inside the cab, different covers for different transmissions. Here's a pic, the AX5 one is on the left, the AX15 on right:
You need to use 4.0 frame horns AND 4.0 motor mounts. The fame horns install in different bolt holes in the frame rails....the threaded holes are there but are not used on the 2.5 version. 2.5 motor mounts look identical to the 4.0 ones, but they're not (4.0 ones are a tad taller). Here's a pic of the 4.0 frame horns installed, see if yours are in the same position:
You will need an AX15 specific trans crossmember.....it has a recessed center section to offset the height difference (Ax5, AW4, and BA10/5 trannys all use the same crossmember, only the AX15 one is different). If you don't use an AX15 crossmember, your shifter linkage will not line up and your cat converter will be kissing the floorboard. Ask me how I know.
Pic of the AX15 crossmember, hard to see but look at the center part where the trans bolts to it:
You also need to move the crossmember back one set of holes on the frame rails. Not sure on your 96, but on my MJ the holes were there but not used. There is a stud on each side that my original crossmember used that I had to knock out to install the new crossmember, it interfered with the fit. Not sure if yours has stud or not, so YMMV.
On the TC linkage, you will need two specific AX15 related parts....the bracket that bolts to the trans tunnel and the short rod that connects the bottom of that part to the range lever on the TC. Parts #14 and 15 in this pic:
HTH,
Jeff
