air tools and compressor
Hello Etan...
Not to add more confusion to your choices here but ...
Sears also carries Campbell Hausfeld compressors and air tools. Check out the Web site and compare ...
I would stay away from other compressors or buying anything like this off the internet. You can return the Sears brand or CH brand if you get it home and you don't like it for some reason.
http://www.chpower.com/
This Craftsman compressor is the best one you have considered so far.....
150 max, 6.4 cfm @ 90 psi and a 33 gallon tank.
220V is the way to go !!!!
To convert from 120V to 220V (two 20A breakers) you will need to run another 120V hot lead off a separate breaker. Just to be safe....you should upsize the gauge of the wire (12 to 10) depending upon how far away the main breaker panel is....
Charles
