Need a complete air box set up for a 99 but I believe they are all the same. I also need a fan shroud. I cracked mine in the process of moving everything around. PM me with what ya got. Thanks
I've got the lid from a 99, however IIRC correctly and from your user name I think I do, aren't you the one that was turning your MJ into more or less a 97+ one using 97+ XJ parts? If so you will want to use the box from I believe a 91-96 and the lid from a 97+. The older style box has a longer induction "snout" that pushes out through the front of the engine bay(there is a square hole it fits into) on the 97+ one the snout it shorter for some reason. If no one else responds with a complete setup I can probably get you the 97+ lid with an older box it'd just take me a day or so to grab the bottom half. Let me know what you decide. I can maybe get ya the fan shroud too.
I have a complete air box with KN filter from a 2000 XJ. If you are still looking, let me know via pm and I will shoot you some pics.
Thanks,
George Trilikis
