- Yucaipa, CA
bl|nk said:Autometer Ulta-Lite mechanical Water Temp gauge
http://store.summitracing.com/default.asp?target=esearch.asp&N=110&Ntk=KeywordSearch&Ntt=autometer&x=0&y=0
"Notes Includes 6 ft. capillary tubing."
Autometer Ulta-Lite mechanical oil temp gauge
"Notes Includes 6 ft. nylon tubing."
Yes it runs lines into the interior of the vehicle both the water and the oil temp.
No a mechanical gauge (unless the ubber expensive) is not going to be as accurate as a quality electric gauge w/ sender.
If the gauge had a 'sender' it's no longer a mechanical gauge it's electrical.
"3) "Yes - mechanicals did appear to be more accurate" - another true statement - at the time! Since the mid-1970's, however, the gains in electronic technology, component costs, and assembly methods have made electronic instruments available at a reasonable price and with an accuracy and reliability that rivals even the most expensive mechanical units."
http://www.classicinstruments.net/index.phtml?catid=43
Here's some info I got while researching the "coolant in the tube" theory:
There are two types of sending units. One type uses a Bourdon tube instrument, a capillary tube filled with a special gas, and a capsule, or bulb. The other type uses an electric sender receiver.
The Bourdon tube type works by having one end of the tube attached to the gauge fitting, and the free end fastened to the needle indicator. A Bourdon tube is a round, hollow metal tube. Putting pressure on the hollow end causes it to try to straighten, so that the other end moves the needle on the gauge. Because it is placed in an engine water jacket, the pressure from the coolant temperature causes it to move, which, in turn forces the other end to move the gauge needle. When the coolant cools, the lack of pressure allows the needle to swing back to cold on the gauge.
Taken from: http://www.partsamerica.com/Auto101Cooling2.asp
