xuv-this
bondo afficianado
- southwest VA.
honestly, i don't think you would need it. hell, with my 4" lift there is not a whole lot of difference when i disconnect mine.(with the poly bushings and bilsteins) i know the stock rear bar does nothing on a stock xj. i was told once they were there mainly for towing...you could try poly bushings on it, and see if there is a difference. most swaybar sets run about $15-20DeftwillP said:It would help if I know how to use the thing. My front bar is actually 26mm. If I upgraded to poly bushings, would I actually know the difference vs. 28 w/ poly?
What about the rear? My bar is only 16mm?!? Thats only a 5/8 inch bar. I'm pretty sure addco is the only one that makes an aftermarket rear bar. Did stock sizes vary any??
my setup has some oversteer, and i like it, but that's me and my driving style. actually i think that less body roll does help xj's handle better. like if i haul around a corner, and the next one goes the opposite way, then a stock xj will roll back right as the second turn starts, and throw the weight on the outer front. with less body roll and my setup, i can control where it goes, and how much A LOT better. then i can kick it down floor it and the rear really pushes it through well. i also think that the solid axles really help to hold the inside down, too.MaXJohnson said:reducing body roll doesn't improve handling; at least not on a vehicle with solid axles.
Increasing roll stiffness is common in the world of IFS/IRS vehicles. Reducing body roll reduces problems with camber changes. Controlling camber is necessary to optimize the tire contact patch for maximum grip. If it wasn't for camber changes, the rule would be "softer is better", even with added body roll.On a solid axle, camber is maintained regardless of body roll angle. Roll stiffness is adjusted to balance front to rear traction. "
also, plan AT LEAST 1 whole day to do it. and have a couple of spare bolts handy you can use as temps if it is a DD. then get it aligned. the body kit does not include swaybar stuff, and it runs around $100. ebay might be cheaper.JeepSpeed said:Hmmm, I'm never afraid of working on my truck, and can tackle any job I've tried in the past 3 1/2 years, so the bushings might be a good choice. Any idea on a price for a whole suspension kit?
Thanks alot.
hope this helps!!
