sinat01
- Clarksburg, WV
Ill post pics up either tonight or tomorrow but here is what I have to work with.
I recently picked up a 4x8 aluminum trailer that is already SOA.
I put rubi 5 spoke wheels and 285/70R17 AT tires on it.
downside is I still need a substantial drop hitch for it to set level with the jeep (prolly 8+" drop)
I think the trailer has CJ5 springs under it. 44.5"L x 1 3/4" wide, spring plates match and everything.
I am trying to make this into a camping trailer and a general use trailer, which is difficult lol
trailer needs new bushings and the springs are a bit soft, but new CJ springs arnt exactly cheap.
what is a good hitch setup to use that is friendly on road and to my wallet, but will allow more movement than a normal ball setup?
I also want to make it so I can make an awning using PVC pipe as a frame and a good tarp. that way it can be stowed away fairly simply.
One of the issues I am having currently, is when I have my trailer hooked up to the jeep, if I hit the brakes itll dim my stereo face like I turned my light on, and if I use my blinkers my stereo face and odometer flash in time with the blinker. the jeeps turn signals, and back up lights are LED and have the correct flasher for them, but the trailer uses incandescent bulbs still, could that be causing the issue?
