Adjusting lower Adj cntl arms???
FELIX
Who Knows, Ask Who
Camarillo, CA
A quick ??? on adjusting the lower control arms. Right now, it seems my front axel sits a little to the rear of the truck, if I run {lengthen}, the adj lower arms out a few threads, will it push the front axel forward, & if so, what else will more that likely be affeced.
Thanks as always
Rob
Thanks as always
Rob
Yes, it'll move the front axle forward a little. You should extend the top ones at the same time (if you have adjustable uppers), so that your camber isn't affected too much. If it's just a couple turns though, you'll be fine.
Billy
Billy
also look for clearance with pitman arm at compression on driver side. tierod might hit it if you push the axle too far forward.
