- Rainy side of Washington
I am not sure I am comfortable with the way he wants you to drill the stock mount out and put that bolt in (I'd rather have a tapered stud on it, requires less torque on the nut to get the same effective side load capacity since it results in zero clearance between the stud and the mounting hole instead of requiring the clamping force of the bracket and nut to handle the side loading) but you are 100% correct on the bracket itself. Most aftermarket ones are flat quarter inch plate with a bend to go around the frame that results in a pre stressed/work hardened section of metal there, and no bracing on the vertical section of the bracket to keep it from flexing. I have an RE unit I'm going to be installing soon, it's designed this way, my plan is to weld two 1/2" wide strips of quarter inch plate on edge up and down that section of the bracket to provide some stiffening.I beg to differ as I have seen both claytons and my Ironman side by side and they are the same quality of craftsmanship. Also the factory bodyside mount when fitted with Andy's double sheer conversion that is welded in is stronger than most aftermarket mounts do to the fact that the material used to make the mount is very thick and it has a bend in the outside of the bracket to brace it to resist flex. Most aftermarket mounts are made out of flatstock that will flex. Not dogging on any other aftermarket mounts because they get the job done but this guy asked for a good AFFORDABLE piece and Ironman gets it without skipping where it counts. Claytons and IRO are both very well made products and I would hands down put either one on my Jeep however these names come with a price. All I am saying is Ironman is the best bang for your buck and that is what the OP was asking for.
DO NOT BUY ROUGH COUNTRY OR RUSTYS!!!!
