Re: adapting cardan joint to stock slip yoke
Your summary is mostly correct, but seems to ignore the reality of the two different transfer case output designs. Although the early design doesn't have a bearing at the end of the tail cone, it does have a seal that the slip yoke rides in to help control what Stryker calls "runout" -- that's the more correct term, but I generally think of it and refer to it as "whip." The '96 and newer output shaft has a long and totally unsupported out put shaft. That's more problemmatic.
Many people run up to 4" of lift with no vibes on the old style output design. Virtually nobody runs ANY lift without vibes on the new style. Bluto, if you work at DC you must know that with the new style, even the factory Up Country suspension creates vibes, and the factory authorizes dealers to install transfer case drops to address this (if you cal masking the symptoms "addressing" the problem).
For those who might still consider this, especially with the new style transfer case, just hanging a double-cardan joint off a slip yoke is not the answer. You also want to address that runout issue, and short of a SYE the best way is to shorten the output shaft as much as possible, fix the yoke or double cardan joint as close to the transfer case body as possible (like the RE "hack 'n tap" SYE), and modify the drive shaft to put the slip splines in the drive shaft rather than on the output shaft.
If you have ever watched a u-joint or even a double-cardan joint operate at extreme angles, you know that if the shafts are unrestrained the "knuckle" tends to want to bind up and move laterally (or off the axis of rotation). It's the output bearing that resists and restrains this, and that's why you need the output sgaft to be as short as possible, and the yoke or joint as close to the bearing as possible -- to reduce the effective lever arm of this eccentricity (or runout) on the output shaft.
BLUTO said:
I got hooked-up with a VERY experienced mechanic/parts supplier through Chrysler's transmission labs. I explained what we were discussing on this forum and his experience seems to confirm the various comments and opinions that are being aired on this subject.
Basically, you can use a CV or double-cardan type joint to control vibes on mildly (<4") lifted vehicles. It should work fine. The downside to this is: you are cantilevering more weight off the TC's output shaft and that will cause rear bearing failure on a "quicker than OEM application" frequency. This means that yes, you may have a bearing failure that "could" scramble your TC and other various attached components. Lots of articulation (off-road rock climbing) does not help this scenario along either.
This mod is best used by DD's who see little or none off-roading.
What I got from this is: if you have a lot of $$$ tied-up in your rig OR do a lot of heavy off-roading, then stay with the SYE. If you are on a firm budget, mostly DD, and don't mind the increased risk to your output shaft bearings.....then this may be your set-up!
I will now have to save-up a little longer to get rid of the last of my vibes.
BLUTO
