Adapting cardan joint to stock slip yoke
XJguy
Can I adapt a stock slip yoke to the cardan joint centering ball joint, or will I need a new yoke. Is that ball joint even necessary for a rear driveshaft application.
Do they even have such a slip yoke?
TIA
XJguy
PS: dont want, have the time or resources right now for a SYE kit right now.
ooh finally. I've been thinking of this too recently, a lot. It would have to be better than stock. wouldn't have to worry about clearance in the yoke. You'd obviously need a much shorter driveshaft. But the way I look at it, it has to be cheaper than an SYE.
so will this work??
please don't tell me the advantages of a real SYE, I've heard it all. I wanna know if this idea would work!
It can be done with the right parts.
With what I've read and seen on the subject I can't imagine how this would work properly. You're still going to have all that weight on the end of a 6" long output shaft (even more weight with the double cardan).
Is a stronger bearing being added to the output shaft on the TC to hold all that weight? This may fix vibes but I don't think it's going to be any good for the T-case. The idea is to remove the slip action from the horizontal plane at the T-case and move it to the angular plane at the driveshaft.
Is there more to this than the picture let's on? I've been looking for the inexpensive way out on this myself so trust me I'm not bashing any ideas I'm open to anything sensible.
Mark
I plan to leave the t-case stock. I dont see how a SYE will lessen any weight on the t-case.
RCP Phx, where are those yokes from? Will they fit a NP242? Where can I buy one? You think I can get one from any driveshaft shop? Thanks.
Ahh, never mind followed the source, Tom Woods. But they say they do not recommend what I want to do for the NP242, I wonder why? Well by all accounts I should have had bad vibes by now at 5.5" of lift but I do not, so I am willing to try it regardless of what they recommend...I dont need $1000.00 worth of driveshaft, its more than what I paid for the Jeep!
XJguy
I have been running that for almost a year now. It works fine for mall wheeling. Ran me about 170.00 for parts and the labor to have my shaft shortened. Yes, I just said have my shaft shortened.:D
How much lift do you have? Ill be running 8-9"
Where did you get the yoke and how much?
XJguy
I am at 6.5 lift, and I believe the yoke was around 50 bux...lemme know if you can't find one I can go to the local driveshaft place and find out who makes it.
I thought about it too but have heard that if you have a lot of rear travel and use it the whole extension housing can brake due to the extra weight. The SYE shortens the leverage by removing the extension housing bring it closer to the main bearing support. I think at lifts under 5"-6" and non rock hopping sojourns it would be fine as no someone that has had this setup for a number of years now without problems and fits into the above category.
For the little extra money for a SYE, it will save your fluid if you break a rear shaft and have to remove it.
There is a guy on pirate with a new AA 231 SYE for $200.
I this what you're thinking of?
Yes. It can be done, and I ran one for about 2 years.
I believe the 3 yokes pictured above are like the ones that are manufactured by a certain drive line company out in the Arizona area. They're are a 2 piece welded and machined product that's prone to failure over time and abuse. The one I ran is from Inland Empire It's a one piece cast and machined product. It's designed to accept the 1310 ujoint CV unit. I believe you can either order it direct from them, or you can get your favorite driveline shop to get it for you. This can be used as an alternative to a SYE for mildly lifted rigs. The reason I no longer run it is I exceeded its capabilities with the height of my lift.
I hope this helps.
Thanks,
Dan.
XJguy
It isn't meant to lessen the weight, but rather move it closer to the bearing to end runout.
You can probably address some of the vibration that is being caused by extreme angles beyond 15 degrees, but as for runout....it won't do a thing.
Rich.... There is NO SHORTCUT for a proper operating SYE. It doesn't stop vibes....it addresses the REAL reason for the vibes, and saves the rear bearing in the Tcase.
How much is a new Tcase worth up there? I've blown apart two before I got smart and figured out what I needed was a SYE kit to begin with.
cardan joint to slip yoke
This thread is interesting.... After adding 2* shims to rr springs and dropping TC 1"; I have a little vibration left at about 70-75mph. I run 3" of lift on my 2000XJ, AW4, 242, and 31 x 10.5 x 15 tires. I don't intend on getting much wilder on this DD. If I could fab this driveshaft in the shop, it would save me enough money to buy gears and a posi. I probably won't do much hardcore wheeling for a while (I'm in the midst of a "de-wifeing" mod.....and some of you guys know how expensive that can be
:eek: :mad: !). I need this car to get to work and back day in and day out,...so it has to stay in one piece.
On the other hand, would I be harming the TC by installing this double-cardan jointed driveshaft? I'm looking to get rid of the vibes that are supposed to tear-up our drivetrain in the first place.:confused:
If I was to do something like this, would I want to delete the TC drop and alter the driveshaft from its factory original position? I don't know if I can tangle with a SYE conversion on my 242 (taking TC apart doesn't look like much fun), that means I have labor charges on top of $500 for a SYE and driveshaft! This mod looks more like something I can handle and afford at this time. But, I won't trash my TC to save a buck either..... I was just hoping to get my gears and posi before winter ;)
Thanks for any input you can offer,
BLUTO :)
I hope to gain a few things by doing this mod. I hope add length to the driveshaft by adding all this extra equipement and I hope to avoid any binding issues that I may encounter when flexed up. At 5.5" of lift I had no vibes at all but I did have less slip yoke engagement. But now I am in the process of moving up to 8" and I want to take care of the problems I forsee before its too late, Moab is just around the corner.
My XJ has 135k miles, if the t-case gets damaged I wont feel so bad (though I dont desire this), since its probably in not in that great shape anyway, I already had to open it up when I bought the Jeep to replace some internal plastic components.
XJguy
I hope this helps.
Thanks,
Dan.
That is exactly what I want to do. So at 8" you were forced to get a SYE? 8" is what I am moving to and the reason I want to do this mod, are you saying its not a good solution? I have the NP242.
XJguy
XJguy
I should have said that at 8" it would be at its limit. I never used it at that height. I guess it could probably be done.
The other reason I have an SYE is that I was able to go to RE's garage sale they had back in June 2001. I picked through a couple of different boxes and eventually came up with the parts to do an SYE for a mere $20.00. I also run the 242. I sold it to cbremer off the JU board. But I know he surfs here also using the same screen name. I think he also went to an SYE and may have this thing available. Can't promise that though.
Anymore questions, let me know. Good luck!
Thanks,
Dan.
A buddy of mine had exactly this setup at 6" lift and they couldn't fix the vibes. The 4x4 shop that did this also added a second CV at the other end of the driveshaft but it did nothing to stop the vibes. After trashing the driveshaft and installing a SYE all vibes were gone.
My opinion on this: Save your money and do a SYE
yup... i bought dan's (TRNDRVR) shaft that he has pictured and ran it while saving my pennies for a SYE and driveshaft. I used it for nearly 8 months with the appropriate shims and no t-case drop and ot worked beautifully. unfortunately (for XJGuy ;) ), i did sell it after I upgraded my driveline. if you could have a local shop build a shaft like the one pictured, go for it.
cbremer said:
yup... i bought dan's (TRNDRVR) shaft that he has pictured and ran it while saving my pennies for a SYE and driveshaft. I used it for nearly 8 months with the appropriate shims and no t-case drop and it worked beautifully. unfortunately (for XJGuy ;) ), i did sell it after I upgraded my driveline. if you could have a local shop build a shaft like the one pictured, go for it.
adapting cardan joint to stock slip yoke
So far I have read that there MAY be a problem with excess stress placed upon the output shaft bearings, causing premature failure. I also have heard that they "worked beautifully" and got rid of most or all vibes. I've heard that on smaller (<4") lifts there shouldn't be any issues, especially if there is only moderate wheeling and not a lot of rockclimbing. I've also heard on some >6" lifts that they didn't help much.
Does anybody else with <4" lift and moderate to light wheeling have any input on this? This may be the way I go, until I can cough-up $~550 for a SYE.
BLUTO :)
