- Minneapolis, MN
Unless the t-case is totally trashed, a fresh chain and new shift fork tabs will likely be all that is necessary. My 98 has +284,000 miles and as far as I can tell the t-case has never been cracked open.
Very interesting, which version would I need for my install?
Sent from my iPad using Tapatalk
For the first time I fully disagree with you Tim... there's loads of times I use 2wd low. Even doing things like yard work, backing up to a trailer or anything that requires additional finesse, it makes it easier...
You're correct. My gears are wayyyy off. Sometimes for some thought though. Trails in my neck of the woods require wheel speed. I hit 3rd gear (auto trans) very often in 4x4 low. High range is out of the question as to needing to go back and forth so often (friends with proper gearing have this issue)Slow.
Your gears arent correct for 35s for trail work neither are 4.88s
A dedicated trail jeep on bug tires wants 5.13 5.38s unfourtenatly thats mearly a dream.
2wd low would be Handy since my jeep isnt properly geared eirher
Can Twist through the trees wirhout needing 4wd but wanting to go slow so I can keep from braking my glass.
anyone got any advice on how to not upgrade further?!
Yeah, sell the jeep and buy a ford. Then you'll just have something to look at instead of drive!
Ok! Here is what I have on the way so far!
(Phase 1)
Spartan Locker for the front (ordered)
Extreme duty front driveshaft from Adams (ordered)
Solid D30 diff cover (ordered)
Shop will do install and rebuild front diff
(Phase 2)
JB Conversions SYE (need to order)
Extreme duty rear driveshaft from Adams (need to order)
(Phase 3)
Adjustable upper and lower control arms (ordered)
Longer brake cables (ordered)
New Fox Shocks (need to order)
Hoping that after these 3 phases I’m satisfied for some time but my hunger for upgrades seems to be insatiable…anyone got any advice on how to not upgrade further?!
Get a second set of rims and buy a new set of tires in the same size as you are currently running. Store them until you wear out the current set of tires, then install the ones you have been storing, and buy another new set of tires in the same size. As long as you keep yourself from moving up in tire size you should be able to stave off the upgrades.
