Tready619
- Alexandria, VA
Ok, did some searching, found very good info on the ac units on XJ's. I couldn't, however, find a direct answer to my question. I have a 2000 XJ sport, 4.0 HO. The Ac blows just fine, but the air is not cold. I thought all I had to do was go get a new bottle of the R134 and put it in. Then, I read the bottle and do what it says.
It says, turn the vehicle on, turn to MAX COOL. I did that.
Then, put the hose on the pressure fitting. I did that.
It says if the gauge reads in the " Don't Add, proper amount", don't add any of the refrigerant.
Mine read just fine. I see no evidence of any leaks or problems with the system. I just want it to blow colder air.
My question is, how do I go about getting colder air?
Add this refrigerant?
Drain and refill?
Thanks for all your help.
Tim
Drain and refill?
Tim
