austinaubinoe
- Montgomery County, MD
question... the ports on my compressor look like this:
what are my options as far as putting a fitting on them? they dont appear to me to be a standard thread of some sort.
This is what mine looked like as well. On the input side (big rubber hose) I simply unbolted in from that black cylinder thingy and tapped the existing hole in the aluminum flange. I screwed and aluminum Viar filter directly on it.
For the pressurized side, I cut the existing smaller rubber line, as far from the compressor as possible. Then I jamed a barbed fitting in it, backed by a hose clamp. Plumbed everything from there.
I simply unscrew the filter before use and squirt some all squirt oil in the intake. I only use this to fill my tires and an occasional impact/ cut off wheel.
Oh and you really DONT need to wire it to the ignition. If you try and turn it on while the car is running, nothing is gonna happen. It just turns on the electro magnet and engages the clutch. If they flywheel aint spinning the AC clutch aint spinning.
