danny boy
- Pacific Beach, Ca.
Hey all,
My darn Comanche's at it again. It started as normal on thurs but just wouldn't stay running and now its resting on the side of the road.
Symptoms: Fuel pump primes as usual but upon depressing the schraeder valve on the fuel rail nothing comes out.
So I was thinking (after a debacle of replacing the pump and filter a while ago and finding major debris) a clog in the fuel rail. Well I pulled that apart and it was as clean as can be. So then I try cranking the engine with the fuel supply line off and my thumb over the hole to check for pressure and it definitely gave a healthy squirt.
So now I'm thinking maybe the pressure regulator is just stuck and just letting all the fuel just go back to the tank. Unfortunately I don't have the tool to test for pressure accurately and the truck won't start anyway so I'm kinda thinkin of getting a couple of junkyard regulators and trying that road.
By the way: 89 comanche, 4.0, fuel pump and filter from o'reilly (Kragen).
Any thoughts?
thanks,
Dan
Any thoughts?
thanks,
Dan
