A/C compressor Clutch info???
ubipa
philadelphia
Anyone have info or source on the clutch/clutch coil on the Sanden compressor (709t, model 4784). My compressor works fine, system is charged and works, but as soon as the coil gets hot, it quits. Finding a replacement is being an SOB. Anyone happen to have a clutch coil laying around that could get the dimensions or model number?
sandmcrew2 said:
I just posted like an hour ago about how to fix this. You dont need a new clutch, you need to do the air gap maintinence to bring the warn clutch in. I had the same problem, fixed it for free. look here...
http://www.naxja.org/forum/showthread.php?t=86912
I covered this in detail here.
Good luck
-Jerry
Wow, I did not know that this is what you had in mind. Thanks Jerry.
I was kind a looking for a whole compressor assembly...
Here is a dumb question (since it is dark outside)...Is the Sanden the OEM compressor XJ's? I have a 99 BTW if that matters.
Boris
suhweet....hopefully that's the case, because it'll be a lot easier and cheaper than replacing the clutch. I'll give it a try, thanks for posting!!
