did a poopload of work.
dumb header didnt fit, so i cut and welded
then it fit
then the dumb 99 intake didnt fit over the header, so i hammered
then it fit. and i put on the 703 injectors and more stuff
the idle is way smoother now, so is the power. some people say the 99 intake does nothing but after adding it to two different jeeps i can feel the same additional power through the middle of the rpm range. the thor intake is LOUD... like intake in the cabin loud, but its only under load and not cruising so i can deal with it. the bracket is a PITA and the filter is manically large... not sure if i'd recommend it but whatever, its what i needed to get the winch solenoid where the intake is from the factory. exhaust note under WOT is gnarly.. she growls now with the header singing into the flowmaster 50 series i'm running. the passenger side engine bracket fought me through every bolt, i broke the top alternator bolt, broke all the wiring off of the coil...
runs nice and cool no more leaking coolant, and have plenty of room between the fan and the radiator now unlike before. theres def more vibes with the poly motor mounts and poly trans mount but its nothing intolerable.. and i can just shift into neutral and they go away sitting at stoplights.
next on the list is front tubework, winch, limit straps, additional bumpstoppage, some wiring here and there for lights and the OHC... whatever i have time to get done. jeep is wheelable as-is for rocktoberfest so i'm not gonna kill myself.
