97 leafs
can you do me a favor and send a pic before you take the packs off so i can see how much(if at all) it sags? I have a roofrack with shovel, axe, highlift on it and a heavy ass gas tank skid.
MAKsXJ
You may want to think about Dakota leafs added to your XJ's main leaf.
I like mine alot, seem to flex well, ride well (to me anyway) and add about 3.5 to 4 inches if you use all but the overload spring/ski. They can be had fairly cheap.
You may have to drill out the XJ's main spring and use a bigger bolt thru the leaf pack, but that's an upgrade in it's self.
Just a thought
Daryl
thanks jeonlyep. ill look into it. Only thing is i dont want to lift it right now any more than it is(1.75"), but with the way it is sagging now i'd like to get it level or the back slightly higher if it has to be. I also do tow a jet ski once in awhile.
