olympicgold
anybody have a wiring diagram or ECU pinout for an automatic 97 XJ?
basically I have a Split Second FTC1e fuel/timing curve adjuster that I had bought for my '02 TJ.....but the TJ is no more so now I want to transfer the FTC1e over to the XJ.
The instructions for the TJ say I have to splice into these wires/pins:
blue/white wire on C-1 pin 2
black/blue wire on C-1 pin 4
DG/RD map sensor wire C-1 pin 27
GY/BK crank sensor wire C-1 pin 8
TN/YL cam sensor wire C-1 pin 18
BK/DG #1 O2 sensor wire C-1 pin 24
So does anybody know the equivalent wires from a TJ on an XJ?? thanks in advance!!! been lurking for a while now....great forum!!
