xj_mike
- San Diego, CA
You rear line is currently going into the ABS pump, as is the front line. I did not take any pics of the ABS pump before I took it out but if you look at your prop valve, two lines go from it to the ABS pump.
The rear one (which is actually the front line on the prop valve) you just need to shorten, bend and flair (using the original "nut" from the prop valve).
The front line (rear line on prop valve going to ABS pump) needs to be replace, the tee added and the two front line up under the wiring harness, need to be shortened, bent and flaired.
Sure hope this clears it up.
