Handlebars
NAXJA Member #135
- Albuquerque, NM
1997 Jeep Cherokee 5-speed 2 door located in Albuquerque, NM.
188,497 miles $3900 without winch, $4600 w/ Warn XD9000i winch
This has been my wheeling and exploring vehicle for the past 10 years. I bought a WJ so it is time for the XJ to go to a new home. This jeep is very versatile, at home on Moab Rim and Mt. Blanca or on a multi month camping trip.
Suspension
5 inch lift, RE springs front and rear
OME shocks & steering damper
JKS track bar
JKS & RE adjustable control arms
No sway bars
Currie heavy duty steering
16x8 Diamond Racing Wheels
285/75R16 Goodyear MTRs
Front axle
High pinion D30
4.10 gears, TrueTrac LSD
Chrome moly axles w/full circle clips on the u-joints
Rear axle
XJ D44
Raised lower shock mounts
Drivetrain
4.0 6 cylinder- K&N air filter, throttle body spacer, Borla header
5-speed AX-15, clutch replaced at 153k miles
NP231 t-case, AA short shaft, 2WD low conversion
Tom Woods drive shafts, front and rear
Optima Red Top battery
Body
Rust free NV/CA/NM vehicle with lots of brush scratches and minor dents
Hansen high clearance front winch bumper
JKS steering box/frame rail reinforcements
C 4x4 double tube rock rails
Rusty’s HD transfer case x-member and skid plate
Bulletproof swing out rear bumper, can hold either a spare tire or 2 gas cans, high lift jack & Pull Pal
Backup light with 2- 55w bulbs
Wilson 1000 CB antenna mounted on roof. CB Radio is not included with Jeep.
Hella E-code headlamps, 80/100 watt bulbs, high current relay kit
LED tail lamps
Interior
Air conditioning works.
JVC KD-HDR1 AM/HDFM/ MP3 CD player
XM radio antenna, cradle and aux input wired to stereo for Pioneer GEX-XMP3 (XM radio not included)
CB radio antenna wire routed to right side of console
Tuffy Oversize Security drawer w/ divider kit
No back seat
More photos taken 4/18/2010 can be seen here: http://www.fototime.com/inv/67C64BD40480270
PM me if you want to buy it.
Suspension
JKS track bar
No sway bars
Front axle
High pinion D30
Rear axle
XJ D44
Drivetrain
Body
LED tail lamps
Interior
No back seat
