stewie
The Stats:
96 XJ
4.0L
AW4 swapped to 4WD/ 231
D30/8.25 4.56 gears
35" KM2s
Cooling system:
New NAPA water pump
New NAPA T-stat and housing
Newer radiator hoses (lower does not have the spring- good luck finding one with a spring)
New CSF 3 core copper/brass radiator
New "ZJ" (though NAPA lists it as a 4cyl XJ part now not a ZJ part) mech fan clutch
New heater hoses from front of motor to heater core
Chemically flushed recently and water flushed multiple times since I got her in Dec 2010.
Trans cooler bypassing the radiator (don't get started on over cooling the trans- I'm in Phoenix, it ain't going to happen)
ZJ trans cooler used as power steering cooler for WJ ps pump mounted in front of electric fan
Problem:
It started when I was towing my pop-up tent trailer through the mountains on my way to the AZ chapters event back in March. I started to overheat so I turned off the AC (I didnt have the big ole hole covered from my novak shifter so a ton of heat was getting into the Jeep) and turned on the heater to defrost. That helped on everything but the big long grades. At the top I would have to stop and let her idle to cool down. The Jeep did good for the weekend wheeling with no problems overheating. Most of what I was doing did not require a lot of throttle. The ride home was a lot more down hill than the ride up but still had uphill grades and the process had to be repeated again, but not as much.
Now, she overheats with city driving and highway travel is out of the question. I ditched the taurus fan and put in the ZJ fan clutch and new radiator. No help. Replaced the rest. No result. She will idle fine in the drive way even with the AC cranked, but driving on the street, she will overheat. I do have a winch bumper (dirt bound offroad diy winch bumper) but the winch sits low and does not block much of the radiator at all and no lights on it.
I feared a head gasket leak so I did a block test (blue fluid that turns green with exhaust gases) and it was negative result. I just did a compression test and found the following reading cyl front to back in lbs.:
125
135
130
130
135
130
I do have a cracked manifold. The crack is at the typical location-on the tube closest to the motor at the weld where the two tubes join. But the crack is most pronounced away from the motor tapering to be hairline at 45* upwards towards the motor and then not cracked facing the block or under, so I doubt its shooting hot exhaust gases on the block. And this was checked with the motor running at temp with an inspection mirror.
I'm at my wits end with this. Its going to be getting cooler in a couple months and that means prime wheeling season here- opposite of the rest of the country, so I would love to nail this one down.
Thanks for the help
Stewie
96 XJ
4.0L
D30/8.25 4.56 gears
35" KM2s
Cooling system:
New NAPA water pump
Problem:
125
135
130
130
135
130
Thanks for the help
Stewie
