It is likely a good idea to find out why it melted down or it may happen again. Pull out the fan resistor pack and look at it. Or for a quick test smell it. It may have been a damaged cable, it may be a component hooked to the cable. You also need to have a look at the fan controls and make sure they didn't meltdown also. And look closely at the connector near the base of the steering column for discoloration and/or melting.
