96 XJ - Bypassing ABS - Need Help
MarkF
I plan on bypassing my ABS pump because a) I have a D44 in the rear and B) I can't properly bleed the ABS pump.
Since the Prop has 2 lines and 2 lines out I was planning on using a T to split the front out into L & R.
1) Which side of the prop feeds the front and which feeds the rear. The front line of the MC goes to the front of the Prop and the rear of the MC goes to the rear of teh prop
2) do I need to change to a non-abs MC or is there enough volume in the ABS MC?
3) Will the T not suffice, should I use a non ABS prop instead?
4) Should I discard the Prop and get an adjustible one from Summit to put on the rear line and run everything direct from the MC?
Thanks
