Hi everyone, great forum. I’ve used it in the past as a reference but just made and account looking for help.
1993 Cherokee, 4.0, standard transmission, 4x4.
The Jeep was idling outside work for a few minutes and when I went outside it was dead/would not restart. As of right now it is still broken, and I think it needs a PCM, before I buy one I want to run my troubleshooting by some Cherokee experts,
There was pressure at the fuel rail, so I swapped the ASD relay with the AC relay because I know the AC works. Then I bought and installed a crank position sensor because I’ve owned Jeeps in the past. I am not getting any voltage to the ignition coil. I tested continuity from the ignition coil wire grey to PCM 19 grey and it checks out 0.2 ohm. I tested continuity from ignition coil wire green/orange to PCM green/orange and it checks out 0.1 ohm. Key on, engine off - no voltage from PCM 19 grey wire. I visually inspected the engine grounds and 02 sensor wires, no obvious issues.
I know the cam sensor can effect the Jeep starting, the distributor and sensor was replaced about 3 years ago by the previous owner. Also, correct me if I’m wrong, but failed cam/crank sensors will interrupt the green signal wire, the grey wire should have continual voltage ? I pulled the PCM connector off and checked for issues with the pins or corrosion but found no issues.
There are no wiring issues leading to the PCM but the PCM is not outputting any voltage to the grey ignition wire. Should I replace the PCM?
Side note: I’ll add a picture of my XJ, some of you guys might be slightly aroused. It’s a rust free, stock, great condition 2 door stick shift. Cool little Jeep.
