91 Commance Fuel Hanger J bolts
Rick_91MJ
NJ
Hello,
I need to drop my fuel tank to access the brake lines behind it, according to the dealer the fuel tank J bolts have been discontinued. Anyone have an idea where I can try to locate these? They are not typical bent pieces of rod but rather the ends have a disc shape to engage in a key hole slot in the frame.
Thanks,
Rick
91 Comanche
wow, that sounds like a royal PITA, i do think they're are some snaps for the breaklines behind the tank, if it were me, i would just pull the line out and slide a new one in, try and bend it the same as the old one
do you have the factory gas skid?
when we had to pull my freinds bed off, the gas tank was a bith to get, it was welded on several places
when we went to pull the staps off, the j hooks actually pulled out and broke the body, the nuts were severly rusted on there
the dealership would be the best place to get some or those hooks, if you managed to find some at the junkyard they would probably be rusted
you might get lucky and check napa, autozoo, advance, they might have some universal hooks, i've seen them on other trucks before
good luck
