90 Cherokee for sale
Wild Bill 43
Utah
1990 Jeep Cherokee
Aftermarket HD diff covers (Blue Torch Fabworks)
4.88 gears with ARB's front & rear
Superior Super Dana 35 Axle kit (rear )
Solid axle shaft on long side of front Dana 30 (No vacuum lines
)Rear axle brace (on top of the axle tube)
Tom Woods rear drive shaft
Transfer case was gone thru in 2005 by Sky's Extreme Offroad
Sky's Extreme 6 inch lift
Doetsch shocks with Shock Limiting Straps
Shock brackets converting Stud shocks to eye bolt ups
New Motor Mounts (Rusty's Offroad)
New Track bar & mounting bracket (Rusty's Offroad)
Teraflex High Steering System
Custom weld-in plate for front flex-joint (on axle) with hole for greasing
Custom 3X3X 1/4 inch angle welded to frame (for stiffening)
Custom front & bear bumpers
Custom Rock Sliders
Aluminum Radiator
Remote Dual Oil Filters Oil cooler Aux tranny cooler
Bushing up grade on front anti-sway barSway Bar quick disconnect
K&N Air Filter setup
Driving lights Roof rack
Pioneer Stereo
Bushwacker cutout fender flares
Custom exhaust manifold from Predator Offroad, Colorado Springs, CO (Not headers)
Hood scoop (to let hot air escape while going slow when 4 wheeling)
15X10 Imitation Beadlock steel wheels
33X12.5X15 Goodyear tires
8000 lbs Smittybilt winch (can be used front or back)
$3800.00
in Roy Ut
Pic's here https://www.facebook.com/media/set/?set=a.10200838971441783.1073741826.1388865364&type=1
Was told by previous owner that the motor, trans, transfer case, axles had bout 90,000 and body has 220,000 when I got it in March I have put cpl more thousand on it since then.
