MuddQueen
- Abington, PA
Okay so I finaly dove into the guts of the XJ and had a couple questions. First of all, I cannot locate a radiator fill cap anywhere on the radiator or underneath. It seems that the resovoir up at the top (near the pass. side firewall) is the only way to fill it?
Also, I was going to replace the coolant line from the resovoir to the water pump, and also the heater core line (right next to each other), and it seems they are permanantly clamped. As in, I have to replace the entire assembly? I tried looking up anything in Quadratec or 4WD, but no luck. So, in order to replace those lines am I going to have to go to the dealer?
Thanks!
Thanks!
