cruiser54
- Prescott, Az
Just use NGKs.
I just may have to try one of these too!!!
http://www.carid.com/1987-jeep-cher...ies-iridium-electrode-pulse-plug-4268468.html
They sound amazing!
Sorry I'm late to the party, but I thought I'd throw my 1 1/4 cents in. I apologize if this has already been covered.
Regarding the fuel injection connector pigtails: Replace all of them. This is my story. I have a '95, 4.6 L stroker. A while after the engine swap, it started missing. It also was throwing a CEL, even before the stroker exchange. Never bothered to read the code. I traced the miss to a flaky cable, not connector on the #5 and/or 6 injector.
Bought 6 new pigtails from Rockauto for $5 a piece. Nice connectors, 6" teflon wire pigtails. I was going to just replace #5 and 6, but by the time I got into the harness and traced and separated the wires, it was only han extra 1 hour to replace all 6, inline spliced, cable extended to firewall, soldered and adhesive shrink tubed.
When I was finished, not only was the miss gone, but the CEL was gone, and I went from 12 to 15 mpg on the highway. Could I have had intermittent other cabling? Did I disturb some other wire? I dunno, but things are a lot better for the effort.
Back when I was in Junior College, about 290 years ago (70s), I spent quite a lot of time in the automotive program. Should taken my certification tests- could have passed them then. Anyway, a 1970s' stock V-8, in good condition, with fresh plugs took from 5-7K volts to fire the plugs. My '68 440 Magnum with 10:1 compression took about 9K volts. A tired engine, with ancient fouled plugs, took from 17-30K. Considering the poorest quality ignition system is capable of putting out 25K, and the 70s GM HEI systems nearly 70K, developing enough voltage to fire a plug in a decent engine, with clean plugs isn't really a big issue. One of the biggest reason for the introduction of High Energy ignitions was to have far in excess the voltage needed to fire a plug, as the smog laws dictated cards has to pass at 50,000 miles, with no maintenance. So, an ignition capable of 50K Volts could still fire worn out plugs.
So, in your case. I'd have to guess it is more of a plug type and heat range issue your fighting, trying to reduce fouling from excessive oil consumption. If only 3 of your plugs are really fouling, and your burning a quart every 1200 miles, the 3 bad cylinders are getting the equivalent of double that amount of oil. And if it is leaking down the valve guides, as opposed to past the rings, that may make matters worse.
Stroker motors are really, really nice! (hint)
David Bricker / SYR
8Mud said:A completely unrelated thought as to the cause of your fouling. Could be valve seals, most times when they act up it is because of excess side play in the push rods, the specs are in the book, you need a dial gauge.
Okay, here's mine. I operate and maintain a propane powered delivery truck at work.
Propane requires alot of voltage to fire the plugs because it goes into the combustion chamber dry, not wet.
We must replace plugs and wires every 10K miles to avoid backfiring caused by high resistance in plugs and wires, and then igniting another time and blowing pieces of the intake tract to smitherenes.
The boss was using AC platinum plugs. Backfires were occuring before the 10K interval. I called the company that supplies the replacement parts for the propane system for advice. First thing they asked was what plugs we were using. Turns out we were using the wrong plugs. According to them, the platinums have higher resistance than standard old plugs. So, we starting using AC R43LTS plugs. Truck ran better and would go the full 10K miles without backfiring. We also noticed there was much less white residue on the standard ACs at 10K than with the platinums. But the plug gap would be about .040 from the installed gap of .035.
I decided to try something different. I used NGK Coppers the next time around. Guess what? NO white residue at 10K miles. Gap was at .035, and the center electrode was square, not rounded like the ACs at the same mileage.
Fast forward a bit. I had an intake backfire. REmoved all the plug wires and tested them. The wire going to the one NGK, which did have some residue, had very high resistance. Therefore, I'm thinking the high resistance could very well be the cause of the white residue build-up.
Propane goes into the cylinder total vapor. No liquid at all. This info comes from Acme fuel systems who has never steered me wrong.
I'm referring mostly to the white deposits, not oil fouling. That's what we got with the platinums but not with standard plugs.
