Update. I am now pretty sure all OEM crossovers are Bosch #8 the hottest, Champion #9 the mid range, and NGK is a #7, the coldest range. Champion numbers are the reverse and they do not cross or match directly.
That would explain why most people have trouble with Bosch missfires, they are way too hot for their engines and heavy feet, LOL, as most of them have great compression (I suspect).
In my case I may need to move up one notch to a Bosch #9 heat range for my two weak cylinders.
I did an ohms test on the plugs I have to test the core resistance of the plugs I have, and I was
shocked!!!
My used Bosch platinums measure over 20,000,000 ohms!! I am wondering what new ones read (IIRC they did read under 20,000 ohms), and wondering if that was why they fouled???? But I have 4 of them, so I think these were the working plugs in 3,4,5 and 6 when I first started on this issue.
The new Champions read 43,000 ohms
The new Bosch Copper Superplus read 6,700 ohms
The New and used (the recently pulled original #1 and #2) Autolites single platinum read 5,200 ohms.
Wish I new what NGKs read, but I don't have any.
8mud, this makes your topic of wire resistance even more interesting!!!!
