Update. Jeep ran great the last 1600 miles, then had a miss fire out the tail pipe Sunday night on this one....got it home OK, 30 mile freeway drive home at higher rpms. Turned off the torque converter lock and drove home in lower gears to keep the rpms up where it did not backfire. Freeway run at 70 mph, 34 miles, 3000 rpm, and then it was OK in the 0-30 mph neighborhood trip to the house. Not the back fire was not a large loud backfire, more like a whimper backfire, early warning!!!!
Pulled the spark plugs, and #2 was pretty cruddy again, like before when I started this thread, except no signs of black oil on any of the plugs. #1 was not as bad as before, and #3 had some traces of crude (It was clean before IIRC). 4,5,6 were good, still like new.
The plugs, Autolite only have 1600 miles on them, since I changed the valve stem seals (on #1 and #2) and plugs on all six.
I am thinking of trying different plugs on the front 3, maybe go back to Bosch Platinum. I am going to add some Bars leaks fiber pellets to the cooling system, in case it is a tiny head gasket leak starting, but I have not lost any coolant in 2 years. Cooling System is still tight and full.
I also plan to add some Restore in case the compression is getting a little too low, try to give it a little boost. The last compression tests were down around 130 psi (280,000 miles). I did find out I was nearly out of oil. Added a good 2-2.5 quarts. Too many jeeps and cars, and I lost track.
It had the old valve train tick back when I fired it up, but I let it warm up and ran it at 3800 rpm for 2-3 minutes and the tick stopped, and went back to the old normal. Will test drive some tomorrow.
